2 members (Steveoreno, 1 invisible), 126 guests, and 4 robots.
Topics128,269
Posts1,058,402
Members48,485
RAK
Offline
Finally got everything working.New brake switch,new headlamp switch ! Now it appears that the running lights are brighter than the brake lights ? Is this normal or is there a fix.The running lights seem very bright and when the brakes are applied it get slightly brighter ? These are new repro. tail lights.
you probably have the wires reversed, the brake light should 'overwhelm' the tail light .... what happens with the turn signals? the signals activate the brake filament and need to be seen clearly
I second that motion that the wiring is crossed. You will probably find that the blinker is not visible.
1951 1 Ton Completed
RAK
Offline
I'll check that.Report back. Thanks
RAK
Offline
Wires reversed,problem solved ! Thanks guys.
