| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hey all, Grant here. Any tips or pointers on installing the aftermarket headliners? The rubber strip seems to be the drag. I hope to hear from you! Thanks, Grant. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Spray silicone lube (keep away from surfaces need ing to be painted) heops a long way to ret that strip in. Just be patient with it, it will go in. For holdng the liner itself in place, I suggest 3M Super 777 spray adheasive. Good stuff.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I pitched that rubber strip and went with a push on trim. Here's a link. | | |
