0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#519802 03/22/2009 8:37 PM
There are 4 of these what looks like standard 1/2" pipe flanges located at all four corners on the roof of my 51 1 ton panel.
Has anybody seen this setup before? Could this have been the base for someones do it yourself roof rack?
Thanks,Paul
Roof rack flange?
51 1 ton Panel
Betty, she's a handful
I'd say they were either for lights or a roof rack. I had a 53 panel once that a plumber installed(welded) a pipe rack to the roof. Kinda made a helluva mess out of it.
I guess I'm lucky that mine are screwed in. Just trying to decide whether to keep them or not, might screw a satellite dish or something in there. That will be sure to get some people scratching their head. Except most of my neighbors have pretty much gone bald since I've brought Betty home.
Paul
Your panel is an inspiration Marty
51 1 ton Panel
I would guess that some time over the past 58 years, someone made a roof rack out of iron pipe. While clever in the use of low $ materials, the pipe threads are a weak link and that is where the pipe will break. That is my guess as to why only the flanges are left.
I would remove the screws and weld the holes shut
My '51 1-ton panel has the same thing.
