8 members (J Lucas, greenie-reddy, homer52, kades51, 55shaker, Gray_Ghost, 2 invisible),
157
Mod | | | Forums66 Topics128,260 Posts1,058,321 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | There are 4 of these what looks like standard 1/2" pipe flanges located at all four corners on the roof of my 51 1 ton panel. Has anybody seen this setup before? Could this have been the base for someones do it yourself roof rack? Thanks,Paul Roof rack flange? | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | I'd say they were either for lights or a roof rack. I had a 53 panel once that a plumber installed(welded) a pipe rack to the roof. Kinda made a helluva mess out of it. | | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | I guess I'm lucky that mine are screwed in. Just trying to decide whether to keep them or not, might screw a satellite dish or something in there. That will be sure to get some people scratching their head. Except most of my neighbors have pretty much gone bald since I've brought Betty home.
Paul
Your panel is an inspiration Marty | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I would guess that some time over the past 58 years, someone made a roof rack out of iron pipe. While clever in the use of low $ materials, the pipe threads are a weak link and that is where the pipe will break. That is my guess as to why only the flanges are left.
I would remove the screws and weld the holes shut
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My '51 1-ton panel has the same thing.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
