| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | Gentlemen! I've read numerous post, but do seem to see anything on specific rotors. I looking to do the disc conversion on my 52, have the hubs out and wold like todrop into a 6 hole pattern rotor?
Any parts numbers? truck/car years to use? caliper/rotor set-up which works the best?
Thanks Guys! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a 6-lug kit. Check to see if it works with original rims. Maybe someone who has done this will respond. | | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | Thanks for the kit info TC, I have looked at this. Looking for an exact rotor to use to accept the 6 lugs! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | " . . . uses the rotors and calipers from a '73 to '77 mid-size GM passenger car (Chevell, Tempest, etc...) to convert from Drum Brakes to the Modern Disc brakes . . . "
Michael,
Have you contacted Classic Parts of America? They are helpful people who can most likely quickly and correctly answer your question (even if you do not buy the kit from them). Tell them you are considering their kit but want to be able to spec out the total cost of additional parts.
Tim
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | All the six bolt rotors are drilled from blanks and as I see only sold in kits so far. once GM went to disc on trucks they went to five bolt, except four wheel drive and then you have a whole nother hub. thats what I had to do for my 51 Chevy. Mike | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '88-'09 Silverado uses a hat style 6 lug rotor, 4x4 '88-'98, all after '99. The '88-'98 should fit ok in a 15" wheel (not sure about a stock wheel on that) the later ones will require at least a 16" wheel.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | | | |
