8 members (Leo, wvstovebolt, SuperSport, Flint48, Red75bronco, 78buckshot, TUTS 59, 1 invisible),
85
Mod | | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | I need some help to determine which engine i have. Upon searching the casting number i cannot find my numbers anywhere this is a Canadian built truck. Casting numbers are head 3695451 block 3835814 is this a full pressure 235? Can someone help me determine what this engine is? It has the triangle plate on the drivers side with the oil line they say is a babbit ponder but it also only has 2 stubs on the valve cover so it makes me think it may be a 235 full pressure engine. I have also found a 261 out of a 55 chevy, what is the difference in horsepower forn the 235 to the 261? I also got a 4 speed trans from the 55 to change out my 3 speed. What would you guys recommend for rear end gears to give me a little more speed keeping in mind i am staying with original brakes. My truck now does 45 mph I would like to do about 60 mph is this do-able or im i grasping at straws. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | If I remember it correctly: A 235 comes with 140 hp and a 261 came with 148 hp. | | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | Thats not a whole lot of hp change not worth the effort if mine is a 235 full pressure is it? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Typically the two studs on the valve cover indicate either a 216 or 235 splash engine. Some later engines are dolled up to look like the earlier 216s by doing that. The 216 will have a side cover that extends all the way up and through the spark plug holes until it hits the valve cover. Some of the 49-53 trucks had splash 235s that had the shorter covers used on the later engines (thanks Tim!).
From my understanding, you can feel the difference when stepping up to the 261, but I dont have that experience.
I dont know about canadian casting numbers, but hopefully that helps to sort out the mess.
Jeff | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The Canadian trucks of that era had 216s with the short side cover. If your engine is original and the truck is anywhere from a 1/2 Ton to a 1 Ton, it will be a 216. The 235s of that era had somewhere around 100 hp. It was only when the compression started to climb around 1954 did the hp start to go up. The 140 hp probably refers to a 1958 235 or later, definirely not 1952. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Thanks to Tim Lederman's wonderful website, we can see that from the performance curves for the 235 and 261 1954 truck engines there is about a 10% or better increase in torque at all engine speeds, and a 20% increase in peak HP for the 261 over the 235. The 10% increase in torque at the lower engine speeds is consistent with the 11% increase in displacement, and the 261 camshaft helps the higher speeds. I remember back in 1958 when i replaced the 235 in my '53 Chevy with a 261 the performance improvement was really noticeable. Hoyt | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Welcome. I never found any Canadian block nunbers either and I've looked a long time.
In summary:
261 in Canadian Pontiacs rated 148 hp.
American Corvette 235 w/ 3 carbs, dual exhaust, high lift camshaft,etc rated 150 hp.
As said many times before there's no replacement for displacement. Try to wear out the splash oiler while you build a hot 261. Have fun.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | Thanks for the info I have started to strip her out for her ground up restoration. I will be swapping the engine for the 55 261 and 4 speed trans. What would you guys recommend for a set of gears? I also would like to drop the truck 4 inches in the rear and 3 inches in the front. Rear drop blocks no problem what do you recommend for the front drop axel or ?. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | gregs 52, I missed something in your original post. That head number is the same as the number on the head of my 1951 GMC. I have a 216 motor. here is a site that lists the vehicles that youe negine appeared in: www.gmhistorian.btinternet.co.uk/canadianchevdatabase.doc Fred | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Greg, I pulled out my old 235 splash oiler for a 261 out of a '58 - 60 Canadian Pontiac. I believe the old engine was just under 100 hp and the 261 is around 150 hp with higher torque as well. I changed my rear end 4.11's for a 3.55 setup from Patrick's in Arizona. When I tore the old gears out, I found that they were badly worn, I feel good about the new gears but it's not mobile yet. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 1953 Panel, did you find a source for the spider gears?
Fred | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yes I did, a guy from this forum who lives 20 minutes away had a complete axle/torque tube set up that he hadn't had the ambition to bring to the scrap yard yet. All the insides were like new. | | |
