2 members (JW51, TUTS 59), 133 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
It's the 315(proof-read everything before you print it up) grin
Hey - maybe he sleeved it down from a 235?
(Please don't call the guy's number and call him names)
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Giving him as much leeway as I can --
Maybe it's a GMC 302 bored .080.
That would make a 314.
regards,
Leon
54TOW,
If he sleeved DOWN a 235 and got 315 CI, I'd love to meet him. headscratch
Stuart
grin grin
I'm going to see it at the Lonestar Roundup again today. I'll get the story.(and a few pics under the hood won't hurt either, eh?)
David Colter
I never met up with the owner, but I managed to get a few more pictures.
I am guessing it either has IFS off a car, or a 1/2 ton front axle With 8 lugs on the rear, and 6 lugs on the front wheels.
The engine was unfamiliar to be by sight, but maybe the pics will help identify it. Driver's side view Passenger side view
David Colter
54TOW,
I don't understand your comment "The engine was unfamiliar to me by sight"...this is what a Stovebolt six looks like.
Doesn't the engine in your '48 look almost identical?? I'll guess the mystery 315 is actually a 235 ci engine.
Stuart
I meant that the oil filler cap is in the middle of the valve cover, where mine are both on the front of the valve cover.
I know what a stovebolt 6 looks like grin , but I was unfamiliar with the oil filler cap location and air cleaner design.
David Colter
That filler cap location (center of the valve cover) was used on some 235s (and 261s, supposedly) in the late 50s - car and truck 235s.
David,
aren't you boys down under supposed to be able to slide a pack of cigarettes under a car for it to be legal?
the long side .... not the narrow width?
that's the rule when i was in 'high scrhool'
some of dem look mighty .. l o w
just how . l o w . can Ugo??
Jim & Caroline
Those aren't all from Tejas(tay-haas) - there were cars from as far West as California and (at least)as far East as Indiana. It was cool to watch 'em start up, hit the air bags, lift off the ground, and roll away. My favorite car there was The Mistress - check out the next 8-9 pics. That fella drove her 100 miles from San Antonio with no backrest. Die Hard folks there. (sorry - I got off topic)
Does anyone recognize the air cleaner on the "undiscovered engine," and any other theories as to the 315 CID?
David Colter
Theory - the 315 is a mistake or a mistype.
It might be an automobile air cleaner that was used for several years (1508 is a sedan delivery - it has a passenger car's engine compartment.
I have seen the rocker cover with the oil filler in the middle on '59 trucks for sure, maybe '58, too.
Bill Burmeister
Leo Offline
Moderator
Moderator
My 261 (58-60 Pontiac) has the breather cap in the center.
Maybe your 261 is a 315, then....
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
55 or later 235 or 261 - notice the low water pump.
The one I like the best is the Eastside Rat Rod Garage truck. I think that is cool.
Professional Novice
Because of the aircleaner it looks like an older version of a 292. This is where I saw the picture... http://www.chevyc60.com/the_engine_page.htm
Nate, The 194-230-250-292 series engines have the distributor near the front and the older 216-235-261 engines have it in the middle. I think the air cleaner you noticed is the oil bath type, used in lots of HD applications.
Professional Novice
Gotcha. Still getting to know my 6s.
