3 members (Wally / Montana, J Lucas, tclederman), 167 guests, and 2 robots.
Topics128,201
Posts1,057,281
Members48,467
Need some help. If you have 60-66 C10 with the fender mount spare tire what size is it?
The reason I ask is my manual says the original size tire for a 65 C10 is a 7.10-15, which is 28.8 inches in diameter. if I put a tire that is 28.8 inches in diameter in the fender mount spare tire carrier it rubs the back of the cab?
So I was wondering what other guys are using for the spare.
Thanks guys,
John,
The original tire size for a 60-66 was 6.70-15 I believe. The tire you are talking about is for the 3/4 ton models. I may be out in left field with this, but come morning I'll go out to the shop and look in my service manual and see just to make sure. After I've checked on those figures I'll get back to you.
Tramp
dj durant
More pix on Flickr
I have a P235 75r 15, there is 31/2 inches of clearance from the cab.
I also should have said that my truck is a short bed.
I also have a step/short with 215/70/15 on the spare mount.
Duke,
Looks like a 215 70 R15 is about 27" in diameter. How much clearance is there between the tire and the back of the cab?
Thanks!
Guys, thanks for all your input.
I must have the wrong fender on my truck? Duke and Ken1960 have over 3" of clearance between the cab and the fender mount spare tire. I have zero clearance with the stock 670-15 tire? I bought the fenders I am using at a local swap meet here in Colorado, they are not original to my truck.
Were there different styles of stepside bed fenders with the spare tire cutouts? I have ordered a 640-15 tire as a spare, so it should have a 1/2" clearance, but I am confused as to why there is a difference.
I have pictures of the truck in the link below.
Your fender looks just like mine. I think they're all the same from '55 to '66. It does appear that your bed is closer to the cab than mine. You might check that out.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I'm not for sure, but I believe there is a different fender for a shortbed model and a longbed model. I got a fender from someone recently and he had a shortbed. It has the hole cut out of it in the part where the tire sits like your picture. But the original fender I had when I brought the truck home didn't have it, and I know it was the original as my grandparents bought it new in 64' and I'm the 2nd owner. It may not be the difeerence in fenders as much as where it is located due to the bed size.
Tramp
dj durant
More pix on Flickr
k10 Offline
Your truck appears to be altered from stock. The stock wheelbase of the shortbed truck is 115". Your's looks longer by a few inches. You might have a newer truck frame under your sheetmetal. The bed also seems to be extremely close to the cab. But that just may be the picture. There should be at least 1" between the 2.
A workaround might be to simply remount the fenders to the rear by several inches.
Take a peek at this stepside from the gallery and compare the wheel locations relative to the fenders.
http://www.stovebolt.com/gallery/images/clark_bob_1961d.jpg
Your bed may have been remounted too far forward. Have fun.
I am inclined to agree with Tramp. I think there are different fenders for stepsides, long bed vs. short bed. My fender does not have the hole for the tire support rod. Which makes me think this fender is for a long bed. Perhaps that is also why the tires appear in a different location relative to the rear fenders?
K10, It is not possible to move the fenders back on a shortbed. From the factory they are already only a little bit away from the rear stake pockets. I checked the wheelbase, it is 115". Bed is 1-1/4" from cab. Frame is correct, I have checked the numbers stamped on it and it does not have any welds where anything has been cut and reworked.
No worries, I ended up buying a 640-15 Firestone tire from Coker. It fits quite nicely with about a 1/2". I have posted some pictures on my webshots link below.
Thanks for all the input.
The original tire size for a 60-66 was 6.70-15, The tire you have matches my spare, but i have the heavy duty c20.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
I took K10's advice and did some browsing in the Stovebolt Gallery section. Upon further review there are differences in the stepside fenders that have the spare tire mount.
Take a look at Jeff Botts 1960 vs. my 1965 in my webshots link below.
Jeff's spare sits much higher because the spare tire fender cut out only comes down to about the same height as the wheel opening in the fender. But the spare sits back into the fender past the spare tire c/l
On the fender I have the spare tire fender cut out goes down below the wheel opening in the fender. But the spare doesn't sit back into the fender to the spare tire c/l.
I am betting they changed this for better visibility and to make it easier to lift the spare up onto the mount. Guess that explains why some spares have 3 inches of clearance to the cab and others don't?
