1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52946 11/27/2005 6:25 PM | Joined: Nov 2005 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 34 | Hi,
I just bought a 1947 1-Ton Panel with a School Bus Conversion from 1953. It is a really great truck, but a little slow (45-50 mph). It has a 4 gear tranny with granny gear (which leaves 3 useful gears). According to a website, it should have a 5.14 rear end.
I saw there are overdrives as well as ring and pinion sets available. Which option is more useful? Which one can I install myself? I would like to reach 65 mph, so I do not get rear ended on the Interstate.
What should I do to the brakes to work with the new speed? Currently they pull in a different direction each day, but work well.
Andy | | |
#52947 11/27/2005 6:45 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd go with a set of 4:11 gears from a late 60s truck. Overdrive trans would be pretty pricy plus you'de need a really heavy duty unit in that bus. You could ad a power brake unit to your existing brakes for better stopping. Keep it simple and don't try to set any speed records with that big truck. | | |
#52948 11/27/2005 8:23 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Any replacement transmission will cost a fair amount. It would likely be cheaper to go with a replacement gearset from Patricks. | | |
#52949 11/27/2005 8:39 PM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | My 1 ton panel had the 5:14 rear when I got it. I swapped out the pumpkin for one with a 4.10 and swapped in aT-5 from a Camaro with the proper clutch swap, too. I have put 17,000 miles on this set up with no problems so far. I have hauled some pretty heavy loads of blacksmithing equipment on some 5-800 mile trips. It is powered by a 261 engine and to be honest I almost never go over 60mph and don't do jack rabbit starts. Search the forums on the brake thing but I do recommend a dual master cylinder. Don | | |
#52950 11/27/2005 8:41 PM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Also, mine's a 53 and I guess the pumpkin was a 4.11. Anyway, it works. D. | | |
#52951 11/27/2005 9:49 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Also on the 47, belive your trans to bellhousing pattern is the last of the old small type. You would need to swap to the next series version bell or use an adaptor to go with a modern trans. | | |
#52952 11/27/2005 10:53 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The ring and pinion from Patrick's is for half-ton rears and won't work in your truck. I like the pumpkin swap from a late 60's early 70's 3/4-ton best for your situation, but they are not always easy to find. (Search this site for details on which ones fit.)
JiMerit is correct, that the '47 has the earlier bellhousing and transmission. To swap to a later trans you'll also need a later, through '53 bellhousing.
I don't recall when the 1-ton changed from huck to bendix brakes. You might look to update the brakes just a few years to have bendix type brakes. If you aren't pulling a trailer and keep the speed reasonable you would probably be okay.
Otherwise I've seen two approaches to putting disk brakes on a 1-ton truck. The hard way is to swap the complete IFS from a 3/4-ton or 1-ton Chevy pickup '72 - '87. The other hard way is to make your own caliper brackets and put rotors on your existing hubs.
If you update the brakes I'll want to know how you approach it and what you learn. I'm thinking about putting disks on a 1-ton and want to know all I can about how others have done it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#52953 11/28/2005 5:06 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I've got a 3/4 ton with the 4 speed tranny and 4.56 gears. I can go 65 mph as a maximum cruise, but I'm spinning the engine at around 3200 rpm. I can hit 70 for short bursts, but it's still barely adequate to keep up with traffic.
Therefore, I have looked into Gear Vendors and found that they do sell an OD unit for the SM-420. You're looking at around 2 grand, but it could give you a true 8 speed transmission, with a supergranny gear, a granny gear, and a 0.78 overdrive in 4th over.
The other option is to adapt a rear end from a later truck. But for a Stovebolt that has limited rpm ability, more gears would be just what the doctor ordered.
By the way, the brakes are strong, but not being power brakes, you have to stand on them pretty hard in a situation, but they do respond. I've even towed with the stock brakes, and towing a car on a flat bed trailer, the brakes will do the job, but you have to plan ahead.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#52954 11/28/2005 5:39 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Hot Rod Dad: ... I've even towed with the stock brakes, and towing a car on a flat bed trailer, the brakes will do the job, but you have to plan ahead. I've done that too. The last time I swore I'd never do it again and that's when I bought the K3500. Unfortunately other drivers weren't always cooperating with my plan and nearly soiled my drawers. I like brakes.
#52955 11/28/2005 7:51 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | As an FYI to you bigger bolt owners - like 3/4 and 1 tonners, you can now get those 3.90 pinions from Jim Carters!!! Shop soon and get that discount before dec 15th. I saw the new item while perrusing the catalogue. I was lucky and found a gear set that I could just plug in.
Also, go get yourself the tallest tires you can find. That helps as well.
Once my 72 is did, I am adding a brownie to mine and I'll try to document what it took to do so. | | |
#52956 11/28/2005 1:06 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Installing a 410 pumpkin from a 67 to 72 GM truck and using tires as tall as the originals will yield about 2460 RPM at 60 mph. It took me three years to find one of the pumpkins. Now I have a 457 sitting around that I picked up just in case I couldn't find a 410. | | |
#52957 11/28/2005 4:59 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You know, I wouldn't hesitate to re-gear my rear end if I could also put some kind of posi or maybe a Detroit Locker in it too, so that it's not 1-wheel drive. Does anyone know if there is something made for our rear ends to get them 2WD?
As far as the tires, when I bought my truck, I had a set of what looked like really tall and skinny school bus tires. When I went to the tire store, I was told that I had a size that was no longer made and that split rims are extremely dangerous. So I bought a set of modern truck wheels and a brand new set of 235/75R-16 tires. The modern tires handle infinitely better, but they are a few inches shorter than my originals.
I know that hurt my top end, but it helps acceleration, and my stovebolt could use all the help it can get.
#52958 11/28/2005 7:27 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | To get the 3.90 gears, you need a '63-'72 pumpkin, anyway. Might as well just get a 4.10 and save $500. The 3.90s are a waste of money for the minimal improvement, IMO. If they were 3.55 or 3.70 gears, it might be a bit different. | | |
#52959 11/29/2005 1:15 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Looking through the new paper version of the Jim Carter catalog, I did see the 410 gear set but not the 390. Also, I couldn't find the bearing and shim kit. Maybe those parts are too common for them to carry. | | |
