1 members (JW51),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 46 New Guy | | New Guy Joined: Dec 2005 Posts: 46 | It looks to me like I have a drain at each side of the windshield. Do these just take rubber hose and go down the side kick panel? Is there a drain for the cowel vent as well? This is a 40 1/2 ton. Thanks,Bob | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Yes on my 46 there is drain with rubber tube on each side of the windshield that goes down the side of the kick panel. Also the cowel vent has a drain hose/tube. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | On my ’41 there was a rigid tube behind the kick panel exiting the cab through a floor opening just in front of the door post. That tube was connected to a short tube extending down from the hole in the windshield framing with a short hose.
The cowl vent drain is connected by hose to an opening in the top center of the firewall
| | | | | Joined: Dec 2005 Posts: 46 New Guy | | New Guy Joined: Dec 2005 Posts: 46 | Thank you for the answers. Is the cowl vent drain much larger diameter than the side drains? I see a larger tube sticking down under the vent. Does a rubber hose fit over the outside of this tube for draining. It just seems too large to me. Bob | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Yes, Bob the cowl drain hose is much larger, can't remember, but it's either 1/2" or 5/8" It should connect to another tube extending through the center of the firewall. | | | | | Joined: Dec 2005 Posts: 46 New Guy | | New Guy Joined: Dec 2005 Posts: 46 | Kip, Thanks, that is what I needed to know. Took a look at your stovebolt page. Your truck looks good, nice work. Thanks, Bob | | |
