| | | Forums66 Topics128,100 Posts1,056,514 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | I have a line on a 3 speed transmission that came out of a 55 2nd series GMC and was wondering if it is the same as the one in my 55 2nd series Chevy? Not having much luck with google so thought I would ask the experts on this site. Thanks
1955 Chevy 3100
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I would assume that they are the same. Can't find my clutch info to verify that much, at least. If it's cheap grab it for now.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its probably the same but some GMC used the hd version which is a Borg Warner. Most Chevy's used the GM Muncie/Saganaw. Then some had O-drive behind them. Can you get a photo out. The GM one has 4 bolts on the side cover. The BW had more then that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That Borg-Warner HD 3 speed was optional in the Chevy also.
Bill Burmeister | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Thanks for the replies. All I have right now is an offer to purchase plus possibly the engine which I suspect is a 270. The owner was told it was a 302 so I will have to see. I emailed my contact with casting #s to check out. Mine is slipping out of gear in third at highway speed which may or may not be internal according to the t/s section of my shop manual. Is there any value in the 270? I know the 302 is desireable.
1955 Chevy 3100
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | If it is the Warner HD 3 speed it will have a fixed yoke and 9 bolt side cover. Photo | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | After all the research, turns out there was a Chevy drivetrain in the GMC. So the trans was the same and I ended up buying the motor for spare parts, which has an "848" head and the original oil filter system. Thanks for all the replies.
1955 Chevy 3100
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hb - now ya know, in Canada GMC was smart enuff to use Chevy engines  Bill | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | hb - now ya know, in Canada GMC was smart enuff to use Chevy engines  Bill Actualy Bill...it was a California truck  Now I am left wondering if it`s a 261.
1955 Chevy 3100
