2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
I have a line on a 3 speed transmission that came out of a 55 2nd series GMC and was wondering if it is the same as the one in my 55 2nd series Chevy? Not having much luck with google so thought I would ask the experts on this site.
1955 Chevy 3100
I would assume that they are the same. Can't find my clutch info to verify that much, at least. If it's cheap grab it for now.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
Riding in the Passing Lane
Its probably the same but some GMC used the hd version which is a Borg Warner. Most Chevy's used the GM Muncie/Saganaw. Then some had O-drive behind them. Can you get a photo out. The GM one has 4 bolts on the side cover. The BW had more then that.
1972 Chevy c10 Cheyenne Super
That Borg-Warner HD 3 speed was optional in the Chevy also.
Bill Burmeister
Thanks for the replies. All I have right now is an offer to purchase plus possibly the engine which I suspect is a 270. The owner was told it was a 302 so I will have to see. I emailed my contact with casting #s to check out. Mine is slipping out of gear in third at highway speed which may or may not be internal according to the t/s section of my shop manual.
Is there any value in the 270? I know the 302 is desireable.
1955 Chevy 3100
If it is the Warner HD 3 speed it will have a fixed yoke and 9 bolt side cover. Photo
Steve
'49 3800
'52 3600
'57 3100
After all the research, turns out there was a Chevy drivetrain in the GMC. So the trans was the same and I ended up buying the motor for spare parts, which has an "848" head and the original oil filter system.
Thanks for all the replies.
1955 Chevy 3100
hb - now ya know, in Canada GMC was smart enuff to use Chevy engines grin
Actualy Bill...it was a California truck wink Now I am left wondering if it`s a 261.
1955 Chevy 3100
