1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 32 Apprentice | | Apprentice Joined: Dec 2008 Posts: 32 | How much difference is there in the front fenders between a 1954 1-ton and a 1/2 ton pickup? I think the wheel cutouts are larger on the 1-ton but I'm not sure how much. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | 1/2, 3/4, and 1 ton fenders are the same. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | 1/2, 3/4, and 1 ton fenders are the same. But be aware the '54 and 55 1st are differant from the '47-'53 fenders.
Bruce | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Are you sure it's a true 1 ton (3800)? 1/2, 3/4, and 1 tons were the same, but when you get into the larger commercial trucks the fenders are different. | | | | | Joined: Dec 2008 Posts: 32 Apprentice | | Apprentice Joined: Dec 2008 Posts: 32 | It's a 3800 (1 ton dually). I'm sure. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | If it's a Dually is it using 18" Budd style wheels, 10 lugs? Then the nose may be like the 1 1/2 ton 4100 series style. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | 1/2, 3/4, and 1 ton fenders are the same. What he said, including the cab.
Bruce | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | But be aware the '54 and 55 1st are differant from the '47-'53 fenders. What he said, including the cab. (sorry - just giving you trouble, Bruce  ) | | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | I have a 3800 Dually. The fenders are the same as the 1/2 and 3/4 | | |
