5 members (Hotrod Lincoln, Stovebolt48, sron48, TUTS 59, MRMEROTH11), 68 guests, and 1 robot.
Topics128,052
Posts1,055,770
#528327 04/14/2009 2:03 PM
I found this parts cab about 2-hours from my home lots of useable stuff and an amazing amount of stuff in the seat pan to sort through. He wanted $450 but we settled on $200 if I took it that day. It came with factory dual horns as well something my truck does not have. A question on the horns there was no firewall relay do they require one?
Nice one Brad.
I'm not sure about the relay issue, but you've got loads of good saveable stuff! thumbs_up
Well found.
More pix on Flickr.
Good find, I started building my second truck from a cab and front clip.
Cant answer your question on the relay either, although I would recommend one.
Apprentice
Apprentice
Got a 51 GMC with dual horns and it has the relay on the firewall just to the right of the horns. Sweet sound too.
You would be better off with the relay. That is the way mine was from the factory.
1951 1 Ton Completed
It looks like a relay came with the accessory matched (dual) horns in 1951. The relay is mentioned on page 41 in the accessories installation manual and is shown in Figure 108.
