7 members (EchoBravoSierra, MNSmith, TUTS 59, Goach2, LAROKE, Gray_Ghost, Lightholder's Dad),
87
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | I was about ready to start the installation of the better steering wheel when I looked in the tech tips area and seen the part that goes under the wheel has a anti rattle rubber ring,I order one from chevs of the 40s along with a couple other things to make it worth the shipping cost and guess what the rubber ring has no ETA and they shipped the order before I could cancle it. So does anyone know if Jim Carters sells it (I have a very old catalog) or could a O ring be made to work so those of you with a 41-6 what have you used for that part. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I was not able to find a good replacement (does not mean there is not one out there - I just did not find one) and have my old cracked one still in there.
Good luck
Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | What I thought was part of the steering wheel is the dried up remnents of one which I might be able to use but I want to find a new one if possible. | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | I think I found one at Jim Carters and ordered it,I should of tried there since chevs of the 40s did not have the horn button and had no ETA on it too and Jim carter did. I told them at chevs of the 40s to put a note on my accouint notify me if a part is not available before shipping. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I ordered one from J Carters. It took a little longer to receive than normal. I haven't used as of yet. If you need in a hurry I'll mail it to ya and you just mail yours to me. I'm a far cry from using Dan | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | If it does not come in by the end of the week or early next week I will take you up on your offer. | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | I got mine yesterday and I installed the steering wheel and now I have a horn,thanks for the offer. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Now that there is a great example of 'Bolter's helping 'Bolter's and I learned something in the process.
My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I look forward to someday figuring out how to get my horn to work. All those litteel things in the end to finish up.....
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My horn works just find, I look forward to having my truck look like Don’s or Tim’s !!! | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | Its not hard to get the horn to work but there are a few parts and nost are available,the only part that I did not see available is the part under the steering wheel. I installed a relay on mine and do not know how it was originaly wired and it works great now. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Interesting thread. I didn't even know there was a anti-rattle rubber ring! My horn doesn't work either. Mostly because there is a short in the wire running down the stearing wheel shaft. It's something I've got to address to get it working again. Got a new horn button from JC because I know I'll probably destroy the old one when trying to remove it. Lot of little parts in there!! BTW, that old horn is LOUD!!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I'm lucky . . . my truck came with an AUTOMATIC HORN. All I have to do is turn the wheel, and it alerts people without being told. Guess that was a special feature in '41 . . .  | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I'm lucky . . . All I have to do is turn the wheel, and it alerts people without being told. . .  HA!!! that's great. Anybody have some good diagrams or photos on how all these parts come together? Looking at the original wiring diagram I don't even see a relay.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Tim:
Go look in the Tech Tips | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | There is a diagram in J Carters catalog here also. Dan | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kip, that's the first I've seen your tech tip on the horn set up. I see you were able to use my pictures of the button assembly. You certainly did a much better job than I ever could have. That's what this place is all about. A cabloration of information to make the best site of it's kind on the web. George | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | AND....George, I forgot to give you credit, I'll send a note to Peg to see if she can straighten that out. | | |
