Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (greenie-reddy, ranchojuan, Otto Skorzeny), 198 guests, and 6 robots.
Topics128,289
Posts1,058,583
Members48,492
Hi Guy's,
1952 '3600'
Hope someone can help me quickly as this is my daily driver.
I have noticed a vibration from the drive shaft over the past few weeks Slowly getting worse. Tonight i checked underside the vehicle along the drive shaft and have found a little oil seeping from the pinion seal on the diff and some movement there also.
I am sure this is the problem.
Is the pinion bearing easy to change ?? I have noticed some bolts holding on some kind of cover, is this for the seal or will this give me access to the bearing? Or do i have a major job on my hands here?
Any help from you guys would be gratefully received as i use this truck every day and need to cure this problem.
Kind Regards
Tim
(United Kingdom)
The short answer is that is you have lateral movement in the yoke, you have a major repair on your hands. The shop manual will show you the steps to take it apart. If it is just a seal than it is not a big deal. For the seal you remove the yoke with a big air gun and socket. Slide the yoke off and remove the bolts that hold the cover containing the seal.
1951 1 Ton Completed
3B Offline
Hy Tom Newton, you most hold the pinion yoke with a large Stillson [pipe] wrench, if you don't do this you take a chance of breaking a tooth on the crown or pinion gear when removing the yokes retaining nut with a large impact wrench, hope that helps
Managed to sort out the pinion bearing play by removing the yoke and then the bearing to reveal a spacer. I then machined 2 thou at a time off the spacer until the play in the bearing was taken up 10 thou in total. All is just fine now, no more play = no more vibration.
Tim(uk)
