8 members (Oswald, Bill Hanlon, Hanks custodian, gswbbc, cmayna, Otto Skorzeny, oldsteve, Stovebolt48), 129 guests, and 3 robots.
Topics128,042
Posts1,055,520
Members48,424
#525840 04/07/2009 9:15 PM
Got my new bed mounted yesterday. The rails were narrower on the new bed than the truck frame so I built and welded on 4 mounts per side that bolt thru the 2x4 and thru the frame. Should work fine for my application. Just need some 2x12 decking and I'm about there. Finally!
http://good-times.webshots.com/photo/2524463020101465522PqbyfM
mounts http://good-times.webshots.com/photo/2827960000101465522YnAFKa
tri5trucking #527584 04/12/2009 5:15 PM
Looks good Matt!
Paul.
1948 Chevy 6400
1964 Chevy 1/2 Ton
tri5trucking #527874 04/13/2009 1:43 PM
Very Nice!
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #528043 04/13/2009 10:21 PM
Matt, I see you live in OR where it rains a lot. I suggest you use treated material for your frame riser board or give it several coats of a good weather treatment solution. It will save you a lot of grief down the road.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #528053 04/13/2009 10:53 PM
thanks for the tip. It does rain alot here but this truck has it's own spot in the shop and won't see it.
