4 members (RaNfLaS, Tyler Watts, DadsFirstPickup, Otto Skorzeny), 99 guests, and 1 robot.
Topics128,048
Posts1,055,663
#527678 04/13/2009 12:05 AM
some of you may remember I burnt a hole in a piston. it was hard, but I got it running and I'm happy!
what all I did:
-replace piston
-valve job
-carb kit
-plug wires
=then it locked up. turned out starter was sticking to the flywheel
-put in 4th gear and rocked it
=then it turned over but no spark
-measured all volts and ohms
-replaced faulty coil
=it runs! so i check vitals: radiator stays cold. to do:
-replace lower radiator hose. it's blocked!
=I decide to drive 2 inches: no brakes. check under truck. to do:
-replace brake line
=also to do: adjust valves
but I'm happy with this!!!
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
Y
Y Offline
Great to see your making progress, Steady as she goes. thumbs_up
