| | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 23 Apprentice | | Apprentice Joined: Jan 2007 Posts: 23 | Hi guys & gals. This is a fantastic idea of a site. Here's my problem; I put a T350 in my 64 where the 3 on a tree was. My speedometer cable is too short to reach the T350. Any ideas or past experiences with this problem? Thanks ahead of time for any replies. Ray
Ray K.
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Either find another cable from a truck w/a automatic OR if you can find an older(late 60's-early 80's) GM car/truck w/a 2 piece cable just add the short one to yours...Joe | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | yea that always happens so you need a cable strecher-or as joe says there are short cablea avaible about a foot long | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | When I replace the SM420 with the A833 I needed a longer cable. I measured the old speedo cable with some string. Then went to the FLAPS and bought a longer cable.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Mar 2007 Posts: 34 New Guy | | New Guy Joined: Mar 2007 Posts: 34 | Hello Ray, when I put a TH700R-4 in my 1966, I found a correct lenght speedo cable at AutoZone. It was manufactured by a company called Pioneer, and was available in various lengths. You may have to do a little digging, but you should be able to find the length you need, and it wasn't very expensive.
Seth K. Pyle | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | You can get a cable from an early 80's model chevy and it should plug right in.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
