6 members (MickeyP, Rexville48, dt235sd, Forty9, David Bush, kades51), 93 guests, and 0 robots.
Topics128,049
Posts1,055,702
#527283 04/11/2009 5:12 PM
can anyone tell me if a 62 c60 frame is the same as a 63 c60 frame or how do i tell if there the same
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
By 62the 34 inch frame was pretty standard. Crossmember spacing might be different, but these frames were not heat treated so they drill easily. Instead of rivets, flange bolts can be used. Flange bolts were used by large trucks until the mid 1990's when Huck bolts became the standard. This is a source of flange bolts. http://www.imperialinc.com/items.asp?item=0191490
crenwelge #527350 04/11/2009 9:10 PM
3B Offline
Hy Perry Dean, according to the parts book 60-62 C60 series frame rails have a different part numbers depending on whether a torsion bar suspension, or a leaf spring suspension was used, But neither of those frame rail part numbers are the same as 63 frame rail part numbers of the same C60 model. So I guess the short answer would be, no 62 and 63 C60 series frames, or their components are not the same, hope that helps, and Keep the rubber side down.
3B #527373 04/11/2009 10:30 PM
are there any numbers on frames and where would i look for them if there are any
both of these frames look the same to me side by side so im not sure what to look for in differences
Perry Dean #527391 04/12/2009 12:30 AM
3B Offline
Hy Perry Dean, the frame pieces undoubtedly had numbers on them at one time, probably stencilled, rather than stamped, probably worn off or painted over years ago. Perry if you do some comparing and satisfy yourself whether or not they are the same, the part numbers are definately different, I learned very early in my career that part numbers are different for a reason, something about the parts is different, that doesn't mean they cannot be made to be interchageable. Good luck, and Keep the rubber side down.
3B #527415 04/12/2009 1:51 AM
thanks bobb il take a real close look at it when i get home im in new mexico now on my way to chinle AZ.
thanks very much perry
