| | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | can anyone tell me if a 62 c60 frame is the same as a 63 c60 frame or how do i tell if there the same | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | By 62the 34 inch frame was pretty standard. Crossmember spacing might be different, but these frames were not heat treated so they drill easily. Instead of rivets, flange bolts can be used. Flange bolts were used by large trucks until the mid 1990's when Huck bolts became the standard. This is a source of flange bolts. http://www.imperialinc.com/items.asp?item=0191490 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, according to the parts book 60-62 C60 series frame rails have a different part numbers depending on whether a torsion bar suspension, or a leaf spring suspension was used, But neither of those frame rail part numbers are the same as 63 frame rail part numbers of the same C60 model. So I guess the short answer would be, no 62 and 63 C60 series frames, or their components are not the same, hope that helps, and Keep the rubber side down. | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | are there any numbers on frames and where would i look for them if there are any both of these frames look the same to me side by side so im not sure what to look for in differences
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, the frame pieces undoubtedly had numbers on them at one time, probably stencilled, rather than stamped, probably worn off or painted over years ago. Perry if you do some comparing and satisfy yourself whether or not they are the same, the part numbers are definately different, I learned very early in my career that part numbers are different for a reason, something about the parts is different, that doesn't mean they cannot be made to be interchageable. Good luck, and Keep the rubber side down. | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | thanks bobb il take a real close look at it when i get home im in new mexico now on my way to chinle AZ. thanks very much perry | | |
