6 members (frogfarmer, Bill Hanlon, RoadsScholar, klhansen, Otto Skorzeny, UtahYork), 151 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#52667 11/20/2005 11:54 PM
Junior Member
Junior Member
I believe my carb on my 54 GMC 248 is a 228BV11..I can buy a new 28BV11. Does anyone know the difference between the two and if the 28BV11 will fit my truck?
Roger
#52668 11/21/2005 2:28 AM
Carburetion specialist
The 228BV11 is a style 228 with choke B (cross) and physical size 11. This is not definative. The definative number is stamped on a round tag approximately the size of a dime which is affixed to the carburetor body (normally the airhorn casting) with a rivet. One could compare the numbers of the two carburetors.
Jon.
The Carburetor Shop
#52669 11/21/2005 6:33 PM
Junior Member
Junior Member
the number on the Zenith tag is 95089 1045 hc is that one right?
Roger
#52670 11/22/2005 2:12 AM
Right spot, but maybe the number is dirty. The 1045 hc is probably 1045 (another digit) c, possible example 10456C.
The 95089 is not a GMC number. Probably someone has migrated the carburetor to your truck.
Jon.
The Carburetor Shop
#52671 11/22/2005 4:38 PM
Junior Member
Junior Member
Thanks for all the help..we'll see if it works..
