3 members (Otto Skorzeny, KingG, Hotrod Lincoln), 34 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#526555 04/09/2009 3:11 PM
After replacing gaskets and other things yesterday I managed to forget to plug the hot wire running to the electric choke which inturn fried something. The wire runs to the ACC on the ignition switch. I now have NO power to the switch and wonder in someone in here might have a suggestion. It looks to be an old time painless type. I have checked the very few fuses. I have lights but NO powere to switch. There is probably a fusible link somewhere??? Any suggestions please respond.
Thanks, Steve in Need
bigdog58 #526589 04/09/2009 5:38 PM
Riding in the Passing Lane
You need to take a test light & start tracing. The ign switch gets power from the amp. gauge along with the lights. Beings the electric choke is ad on there might be an inline fuse some where in the wire. You could have burn out the ign. switch.
1972 Chevy c10 Cheyenne Super
I found the wire and got a new one installed. Now I ca drive this thing with NO oil leaks...finally. Found that the crank dampener had a big groove and needed replacing. Went to the one piece oil pan gasket and got my Corvette valve covers installed.
I will be posting some new photos of the new stuff this weekend if the rain stays away. Thanks for the help partner.
Steve in Idaho
bigdog58 #526661 04/09/2009 9:02 PM
You should have asked the fellow bolters for help. There is a sleeve available to go over that balancer to correct the groove.
