0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | After replacing gaskets and other things yesterday I managed to forget to plug the hot wire running to the electric choke which inturn fried something. The wire runs to the ACC on the ignition switch. I now have NO power to the switch and wonder in someone in here might have a suggestion. It looks to be an old time painless type. I have checked the very few fuses. I have lights but NO powere to switch. There is probably a fusible link somewhere??? Any suggestions please respond.
Thanks, Steve in Need | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to take a test light & start tracing. The ign switch gets power from the amp. gauge along with the lights. Beings the electric choke is ad on there might be an inline fuse some where in the wire. You could have burn out the ign. switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I found the wire and got a new one installed. Now I ca drive this thing with NO oil leaks...finally. Found that the crank dampener had a big groove and needed replacing. Went to the one piece oil pan gasket and got my Corvette valve covers installed. I will be posting some new photos of the new stuff this weekend if the rain stays away. Thanks for the help partner.
Steve in Idaho | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should have asked the fellow bolters for help. There is a sleeve available to go over that balancer to correct the groove. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
