| | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, the casting number in your picture is 3831895. My parts book says the drums we found fit a 5000 Lb. axle, the p/n for that axle in my book is 3852520 which superceded 3831896. That axle was used up to 1966 exc. tilts, hope that helps. | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | hi perry nice old truck it says you have the rear end out what kind is it? got that info from the gallery page my 65 c60 bus has a 5000 lb front axle and 10000lb rear im about to do the brakes on the back,already did the fronts got parts ok timbuk | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | thanks 3b and timbuk now i know i have a 5000lbs axle i have a 62 c60 that was wrecked im going to rebuild that front axle to put under my 63 sand blast it and clean n paint it then redo the king pins n stuff like that {glad i wasnt driven the 62 it got hit hard} agin thanks for all the help {i love this site}
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, I decided to do a check and confirm the two axles were interchangeable, and the two parts books I checked, only list 9000 Lb. and 11000 Lb. beam axles for 62, so check carefully before you invest any money in that 62 axle. | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | timbuk when i first got the truck i wasn really interested in rebuilding it so i put a 73 elec 2 speed rear i got from a junk yard in shawknee oklahoma 450.00 put it in and put new brake cyclinders{48bucks} on it new shoes drums are ok now with the new front brakes im not so worried about people pulling out infront of me cuz it will stop now money permittin im gona rebuild the old rear and put it back i found out that brothers carries the wheel cyclinders for it along with most of the other parts im gona need to put it back as time permitts | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | perry it must be better with the 2 speed no? i have not driven my bus yet but i know from the tag its a 7.20 axle it has a clarke 5 speed i did my brothers 63 c60 new brake cylinders etc 4 years ago got the patrs no problem at that time im starting the same job on my bus this week ill document it all on my beta cam......?timbuk | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | yeah i love the 2 speed rears give it that really big truck feel when your driven it i own a 2001 freightliner XLT i drive for a living but its just fun to get in that old truck n poke around in | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | ok perry this is for your info i went to the parts store yesterday and ordered up some wheel cylinders for my bus 65 c60 these cylinders were the same i put on my bros 63 c60 raybestos part numbers 18196 and 18197,upper and lower! | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | ok perry this is for your info i went to the parts store yesterday and ordered up some wheel cylinders for my bus 65 c60 these cylinders were the same i put on my bros 63 c60 raybestos part numbers 18196 and 18197,upper and lower! | | |
