2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I am looking at a radiator on a site, here i sthe exact one: http://www.speedwaymotors.com/Speedway-Chevy-Aluminum-Radiators,3557.html
It would fit in my 51 gmc if I turned it sideways and bought the plug for the filler and then put a new filler cap directly into a splice on the upper radiator hose. Is this realistic to do? The only thing I don't understand is: can you use a radiator in any position? Sideways/slantwaysupside down, right side up etc?? That will answer my question. Thanks.
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | I don't see why not, the water pump should control the water flow. You could always just move the filler cap to the top of the tank. http://www.afabcorp.com/AFCO_Dynate...ode=80147NT&Category_Code=hr_rod-radLook at the link and you will see that this core is running up and down just as your would be. You will need some mounting flanges, simple angled aluminum will work, again see above link. You are looking at a dirt track radiator, they work really well, Dad has one cooling his 478 ci Pontiac that has a block half filler with concrete. (concrete is for cylinder wall stiffness on race motors) Mounting will be you biggest challenge. Joe
