0 members (),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | Just rebuilt the Tranny (sm-420) and installed. On test drive under accelaration no noise, when I let off the gas and coast, I get a vibration and banging sound what I think is coming from the drive train. Feels like the u joint, also the problem existed prior to pulling the tranny.
How can I be sure it is the U joint? and if it is, do the rebuild kits work okay?
Thanks all.
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | can you just get under and feel and see how much play is in the ujoint? i am not aware of rebuilt kits for u joint, usually just bet a new one. 10 or 20 bucks for the ones i have done. good luck, hr | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Check the drivelines to be sure they are in phase with one another. That means all joints must be at the same clock position, front to rear. Since yours would be a two piece shaft you must have a slip yoke/stub shaft in the middle. Not getting the slip yoke back in phase with the front is a common mistake and why it is important to mark the position when disassembling. | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | I think there is only one U joint on my 51 1/2 ton truck. Its an enclosed TT. Correct me if I am wrong??? thanks Money.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, there is only one u-joint on a 1951 3100. Yes, there is a u-joint repair kit for your truck and it fixes most u-joint looseness, except for looseness of yokes on splines. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Almost sounds like a rear end problem. If the U-joint was real bad you would have noticed when you were putting it together. Pull the cover off the rear end & see if the carrier is snug in its bearings. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | could it be the bushing for the torque tube? I think that they call it the okie bushing? | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | I'll check that wrench, thanks.
Don, where is that bearing located?
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | wow, i didn't know those older style had a repair kit. course i haven't had a truck with a tourqe tube. | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | Dumb question time, looked at he exploded parts view in manual and dont see anything called a carrier. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0414.htmWhat is the carrier? Thanks !
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | THe carrier is part of the rear end assembly. The ring gear is bolted to it & the spider gear assem. is inside. It should not have any side to side play but will have a small amout of backlash in the gears. Likewise with the pinion gear. The book probably calls it a differential carrier. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | Thanks Wrench, that helps, Ill check it out.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Before you go much further. Remove your differential cover. Based on your symptoms, your pinion bearings have probably failed. Take a look at my webshots page and you will see what I mean.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | thanks for sharing those pics. I will check there first along with the carrier, then move up the TT. Thanks all.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1951purney, the "carrier" is part of the differential, if you take the cover off the diff. as Wrenchbender Ret. suggests, you can check and see if you can move the "carrier" [the part that the crown or ring gear is bolted to] side to side. If you can move it, then your carrier bearings are worn, and the differential should be rebuilt. You can try to tighten the bearings up, but do not adjust the backlash tighter than the high end of the clearance specifications, that should allow the gears to run together without running on the wear ridges of the gears. This does not take into account any wear on the pinion bearings, or the "oakie" bushing, which is in the torque tube up near the transmission. How long a re-adjustment of the bearings will last is anyones guess, hope that helps. | | |
