5 members (Southerntruck, DaveV, baldeagle, 55shaker, jmoore), 78 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#525120 04/06/2009 2:28 AM
Are condensor's the same whether you have original 6-volt system or if you've upgraded to 12-volt system? Also, are points the same, whether 6-volt or 12-volt? Thanks.
You would have to check by part number but my guess is that they would work fine on 12 V. The only possible change that I can think of is maybe the condenser is a different value to go along with the different impedance of the 12 V coil.
1951 1 Ton Completed
You might want to post your year and make of truck (and/or put your truck year/make/model in your Profile), just in case there are subtle differences that people might want to bring to your attention.
It looks like the same condenser was used from 47-62 (maybe '34-'72?) and a different 6-cylinder condenser was used from '63-'76. Since 12v became standard on Chevrolet trucks in 1955-2nd series, it looks like the 6v condenser should work (maybe someone will know if pre-47 6v condensers will work with a 12v conversion).
Nonetheless, the same part numbers for condensers and points are shown for at least 1946-1962 216/235/261 engines.
Maybe the 6v condenser works because a ballast resister is used before the coil/points in 12v GM vehicles (up through 1976?)?
Points are the same (for 6v or 12v systems) - whatever fits your distributor.
Riding in the Passing Lane
The points & cond. are the same for 6 & 12 volts but tou must use a resister in the circuit for 12 volts. You should have a bypass system for the resister when starting.
1972 Chevy c10 Cheyenne Super
