| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 54 | I've seen a truck with dual exhaust and dual exhaust tips that come out through the running boards of a 1951 Chevy truck that I really liked and would like to mimic on my truck. I searched the forum but couldn't find anything on this topic. Anyone have any insight/specific guidance on this? Appreciate it very much! | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | From past experience I will say they won't sound as good as full length pipes. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Are you referring to cab stacks? | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | It's a quick way to ruin a good set of running boards, and if the pipes are mounted rigid to the cab corners, you'll need to run at least a short piece of flex pipe from the bottom of the upright pipes to the ones going to the exhaust manifold. There has to be a little movement available since the engine/trans is mounted in rubber. Flex pipe wears out and/or leaks in a very short time, so you'll be fixing leaks often. Jerry
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | well unless you are going to run insulators over the pipe ends don't bother painting those running boards the heat off them will take any paint or coating right off those running boards and for arguement sake say you do run insulators they require 1/2" gap around the exhaust and last time i looked running boards arn't thick enough to evelope those under the running boards would be about the best you can hope for
1937 1/2 ton
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have to agree with Jerry, it's an excellent way to ruin a good pair of running boards.
