4 members (1955 1 Series, 49choptop, 3800GUY, Shade Baby), 99 guests, and 0 robots.
Topics128,110
Posts1,056,274
Members48,439
I've seen a truck with dual exhaust and dual exhaust tips that come out through the running boards of a 1951 Chevy truck that I really liked and would like to mimic on my truck. I searched the forum but couldn't find anything on this topic. Anyone have any insight/specific guidance on this? Appreciate it very much!
From past experience I will say they won't sound as good as full length pipes.
1949 Chevy 6400
1931 Chevy Firetruck
Are you referring to cab stacks?
It's a quick way to ruin a good set of running boards, and if the pipes are mounted rigid to the cab corners, you'll need to run at least a short piece of flex pipe from the bottom of the upright pipes to the ones going to the exhaust manifold. There has to be a little movement available since the engine/trans is mounted in rubber. Flex pipe wears out and/or leaks in a very short time, so you'll be fixing leaks often.
well unless you are going to run insulators over the pipe ends don't bother painting those running boards the heat off them will take any paint or coating right off those running boards and for arguement sake say you do run insulators they require 1/2" gap around the exhaust and last time i looked running boards arn't thick enough to evelope those under the running boards would be about the best you can hope for
1937 1/2 ton
Ex Hall Monitor
Ex Hall Monitor
I have to agree with Jerry, it's an excellent way to ruin a good pair of running boards.
