| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | anybody in here know where to find a bolt on alternator bracket for an alternator? Had a few ideas but still looking.
Thanks, Steve in Idaho | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that style will work on a TF truck if you're using the side mounts, will require modification with the original front mounts - you can rig a mount easily to put an alternator on the rams horn the same place the generator mounts Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I mounted mine pretty much as Bill did (I have side mounts). I bought a kit on eBay that has the top bracket as in Bill's photo and had a bracket for the bottom side of the alternator that bolted to the header (I think they are Corvette headers). I couldn't get the bottom mount kit that "old dog" linked to, to line up correctly with my engine (62 283 with a short water pump). Although I have seen it used on what appears to be long water pump engines. Thanks to Bill's advice I was able to identify the proper mounting kit. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Try Bill's Hot Rod Parts in LA....they have many different bracket setups. | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Thanks for the info...I will check them out on Monday. | | |
