1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#52484 11/16/2005 11:24 PM
Apprentice
Apprentice
Howdy folks, I am restoring a 1952 GMC long bed with a 5 window cab, 270, and a 4-speed SM420. The carb is a Zenith 11275D, and takes a filter in the top cover. Ican't find one anywhere, and the original is long gone, so I don't even know if it was paper or brass. Can anyone help me out? :confused:
#52485 11/16/2005 11:32 PM
if you mean the filter in the removeable glass bowl, they were originally metal [bronze?] but there are modern paper ones that fit in properly
#52486 11/16/2005 11:39 PM
Apprentice
Apprentice
Thanks Bill, but the filter I am talking about is actually in the top (choke housing) on the Zenith, under a Banjo bolt, sealed with a fiber washer. It is right next to the brass plate bearing the carb number.
Tom
#52487 11/16/2005 11:46 PM
Here's a picture of one. http://community.webshots.com/photo/189861216/231907021GsBdCQ
You will have to post a ad in the Truck Parts Wanted section of this forum. I've never seen one for sale through any company. Cecil.......
#52488 11/16/2005 11:57 PM
Cecil,
That truck is a BEAUTY.
Stuart
#52489 11/17/2005 3:39 AM
Bondo Artiste
Bondo Artiste
Tombo,
Let me know if you can not find one, I might be able to locate on for you.
We would love to see your truck, do you have online photos available?
Take care and good luck with your GMC.
~ Phillip
#52490 11/18/2005 10:32 PM
Apprentice
Apprentice
Thanks Phillip. I'm not getting any closer to figuring this one out. I'll try to get some estimated dimensions this weekend. I don't have any photos yet, but will try to post some soon. Engine is out and apart for bore/ grind/ valve job. Trans is apart for 2nd gear and bearings. Nose sheet metal has been plastic media blasted and is almost perfect. Cab needs corners and inner cowl sides. I'm going to keep it stock except maybe 12v. Tom
#52491 11/22/2005 3:57 PM
Tombo, sounds like you have the same carb I do on a 54-GMC. The filter on mine is basically a stack of about dime sized brass plates. If this is what you have, I am not sure where you will find them. Good Luck.
