4 members (dt235sd, BC59, UtahYork, 1 invisible), 91 guests, and 3 robots.
Topics128,211
Posts1,057,471
Members48,473
my gas tank has went from full to 1/2 a tank just ideling for 2 hours. There are no leaks but the engine does smeel of gas
any ideas
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
gauge is bad?
Riding in the Passing Lane
First why would you idle for 2 hours. That is not good for an engine especially a carbureted one. Do you see black smoke? Pull a spark plug or 2 out & see if it has a lot of black carbon on it. It might be like Red says just a misreading gas gauge. If it is rich, you need some carb work or adjustments.
1972 Chevy c10 Cheyenne Super
it did not idle 2 hopurs straight, it ideled periodically for 2 weeks for a totzl of 2 hours while i was replacing all the wiring in the truck. I have pulled the sprak plugs and they were black as soot.
A lot of cold starts and idling without driving anywhere can use up a lot of gas. Clean the plugs and drive the truck to get it sufficiently warmed up and see how it performs.
Fred
