4 members (Gdads51, Otto Skorzeny, TUTS 59, 1 invisible), 69 guests, and 5 robots.
Topics128,181
Posts1,057,177
Members48,465
Anyone know the rough weight of an advance design 2 ton for hauling purposes? Now, is anyone good enough to guess the weight of one with a grain body? Thanks.
No 'bolt yet, but if you'd like to help me out with that, send me a message! Or check out my wanted add in the swap meet.
Guessing ~5,500 lb complete but no bed.
Guessing ~6,500 lb with a mostly wood framed grain bed. if different bed you'll have to estimate from there.
I'd recommend as a minimum an 18' double axle flat trailer rated about 10,000 lb, and a newer 3/4 or 1 ton pickup, preferably diesel.
If you find a model 3800, 4100 or 6100 then a 16' trailer should work.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
My info says that a 2 ton 6409 (stock sides) and 161" wheelbase should weigh in around 5750 lbs. curb weight. ED H
My 1954 GMC 350 conventional weighed 6600 on the CAT scales with no bed whatsoever and the original 270 engine.
1950 GMC 350 COE powered by a GMC 702 Twin-Six V12 / 4L80E combo.
V
V Offline
my firetruck at 161" is 9,640 lbs.
1 Offline
My uncles 1 ton 1997 chevy weighs over 5000 lbs. I've never weighed my 1947 two ton but it's got to weigh decently more than that. I estimate 7000-9000lbs. About any goose neck should haul it easy.
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
I'm not smart enough to guess but may have some useful "data"-
I was lucky enough to weigh my '50 two-ton on a certified scale at work a couple years back. It's a 179" wheelbase chassis with an Obeco 13' combination grain/cattle body and twin cylinder hoist. It weighed 7900 pounds complete.
I used a 14K GVW tag (bumper pull) tandem axle trailer and a single rear wheel (3/4 ton) Duramax to tow it 1100 miles with no problems. I had sway control and equalizers (spring bars) on the hitch which helped out. Would have preferred a gooseneck but this was what I had available.
Good luck and drive carefully !
I hauled 2 AD 6400 Grain trucks from Kansas to Dallas, TX. One at a time. On my 20 ft bumper pull Trailer with 10,000 lb. axles, with a 3/4 ton pickup, with no problem. I had to remove the outer duals to get them all the way on to the trailer.
1949 Chevy 6400
1931 Chevy Firetruck
