| | | Forums66 Topics128,196 Posts1,057,390 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 39 | Anyone know the rough weight of an advance design 2 ton for hauling purposes? Now, is anyone good enough to guess the weight of one with a grain body? Thanks.
No 'bolt yet, but if you'd like to help me out with that, send me a message! Or check out my wanted add in the swap meet.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Guessing ~5,500 lb complete but no bed. Guessing ~6,500 lb with a mostly wood framed grain bed. if different bed you'll have to estimate from there.
I'd recommend as a minimum an 18' double axle flat trailer rated about 10,000 lb, and a newer 3/4 or 1 ton pickup, preferably diesel. If you find a model 3800, 4100 or 6100 then a 16' trailer should work.
Grigg | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | My info says that a 2 ton 6409 (stock sides) and 161" wheelbase should weigh in around 5750 lbs. curb weight. ED H | | | | | Joined: Feb 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 54 | My 1954 GMC 350 conventional weighed 6600 on the CAT scales with no bed whatsoever and the original 270 engine. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | my firetruck at 161" is 9,640 lbs. | | | | | Joined: Mar 2009 Posts: 93 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 93 | My uncles 1 ton 1997 chevy weighs over 5000 lbs. I've never weighed my 1947 two ton but it's got to weigh decently more than that. I estimate 7000-9000lbs. About any goose neck should haul it easy. | | | | | Joined: Dec 2006 Posts: 1 New Guy | | New Guy Joined: Dec 2006 Posts: 1 | I'm not smart enough to guess but may have some useful "data"-
I was lucky enough to weigh my '50 two-ton on a certified scale at work a couple years back. It's a 179" wheelbase chassis with an Obeco 13' combination grain/cattle body and twin cylinder hoist. It weighed 7900 pounds complete. I used a 14K GVW tag (bumper pull) tandem axle trailer and a single rear wheel (3/4 ton) Duramax to tow it 1100 miles with no problems. I had sway control and equalizers (spring bars) on the hitch which helped out. Would have preferred a gooseneck but this was what I had available.
Good luck and drive carefully ! | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I hauled 2 AD 6400 Grain trucks from Kansas to Dallas, TX. One at a time. On my 20 ft bumper pull Trailer with 10,000 lb. axles, with a 3/4 ton pickup, with no problem. I had to remove the outer duals to get them all the way on to the trailer. | | |
