1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Patrick's Antique Cars & Trucks has the 3.55 ring and pinion conversion-set for 1937-1955 1/2 ton rear-ends back in stock. The complete installation kit is also in stock.
These have not been available for about a year and they have a habit of selling out quickly. | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | I just recieved mine from Patricks today.  I guess the fun starts now? Kevin
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Does it include the spider gears? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | No spider gears in the ring-and-pinion set, nor in the installation kit.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Does it include the spider gears? FWIW The carrier in a Canadian torque tube has a bolt circle 3/16" bigger than the pattern on Patrick's ring gear. Carrier modification or replacement with a U.S. component are required for us northern folks. Mine had bronze thrust washers against the spider faces too that I never saw in any repair information.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I was looking in a trader magazine and I notice someone selling a center section from a 55 car. Is it interchangable with the trucks? | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The passenger car are different from the truck. | | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | I got mine as well... Yee haa, 1949 GMC FC102 4 speed 1970 Corvette t-top 350 350hp 4 speed 1997 Chevy Suburban 1500 4x4 1999 Saturn SC1 Bolter#17856
