| | | Forums66 Topics128,035 Posts1,055,441 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52347 11/13/2005 5:29 PM | Joined: May 2005 Posts: 12 Junior Member | | Junior Member Joined: May 2005 Posts: 12 | I've got a puddle of coolant on the floor of my truck (54). I've tightened the hose clamps leading into the heater, but I am still getting a leak. Is it the heater core? If so, how easy is it to replace? | | |
#52348 11/13/2005 5:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Unless the tubes where the hoses are fastened are flatened out of shape its the heater core. They are not hard to remove on these old trucks. Remove the hoses & 3-4 nuts on long studs on the engine side & remove the heater after dissconnecting defroster hose & wire. Dissasemble the heater & remove the core. You can take it to a radiator shop & they might be able to fix it but most of the time it will need a new one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#52349 11/13/2005 6:02 PM | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | there is a guy in farmingdale NY look in hemmings for his name he is reasonable about rebuilding the hearter core about $300 | | |
#52350 11/14/2005 6:00 AM | Joined: Nov 2001 Posts: 16 Junior Member | | Junior Member Joined: Nov 2001 Posts: 16 | There used to be a personal site that listed advance design tips. One tip was if your truck has the recirculator heater, a well fitting heater core can be found in a 66 Mustang. Anyone ever try this? It might be worth checking out, highfive. | | |
