2 members (WICruiser, DaveV), 83 guests, and 1 robot.
Topics128,115
Posts1,056,623
Members48,450
I realize that many of you have changed from 6 volt to 12 volt
I would just like to upgrade from a generator to to a 6 volt alternator.I can purchase the alternator but I am not sure what needs to be done concerning the wiring and conversion. would appreciate any help.
Ex Hall Monitor
Ex Hall Monitor
I converted to a 6v one wire alternator on my 38. I left the voltage regulator in place for appearance sake. I connected the heavy armature wire (A lug on the generator) to the lug on the alternator and moved it from the Gen tab on the regulator to the Bat tab while leaving the wire normally attached to the Bat tab still attached. That allows the current to bypass the regulator & your ammeter still works normally.
You will have an issue with mounting the alternator to the stock generator location. You'll need a special mounting bracket & they are expensive. I used this one.
24601
Charlie,
Have you tried Randy Rundle at 5th Avenue Antique Auto Parts? Randy has that bracket plus the 6-volt alternator (I think he's the source of ALL 6-volt alternators) and instructions. He has good tech tips on his site, too.
Good luck!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
My Toto a'52 GMC uses the equipment ( for the past 2 years ) from 5th Ave. Randys stuff is first rate and comes with good instructions on what to do for installation . Randy is also a Great guy to BS with and will answer questions readily . ED H
So where are you guys buying your 6v alternaters from? New or usesd? Avalable at the junkyard?
Denny Graham
Sandwihc, IL
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
I got mine from Quality Power Denny.
Ah yes, bout $120, that's not a bad price at all. Did it come with the pully or did you have to buy that seperatly?
DG
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
I had my choice of two size pullys. I did have to buy the mounting bracket.
