| | | Forums66 Topics128,115 Posts1,056,594 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Seems sources of 55-59 parts come and go..Not many carry the hardware-type stuff..Looking for those special bolts with the forged washer like shape. Anyone making these? I think the last time I needed them McMaster Carr had something similar.
Keith | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I am constantly amazed at what the local Ace Hardware store has in their bins. May want to give them a try in your areas.
EDIT: the bolts your referring to are called "flanged bolts".
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | "Google Search; it's out there"Try your local automotive body shop and paint store, they have bolts and fasteners.
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | If you have an industrial supply store like Fastenal around close, they have just about any bolt that's ever been made. Get one of their catalogs or check out their on-line catalog to find what you need. They're usually less expensive than the auto supply catalogs too.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Might also try a Marine Supply store - they usually carry a broad assortment of weird stuff. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | If all else fails hit the pick & pull or pic a part yards for a sorce of good used bolts. Flange bolts and nuts can be had off several older cars and trucks. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
