9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop), 105 guests, and 2 robots.
Topics128,048
Posts1,055,626
#52304 11/13/2005 1:15 PM
TT
Offline
The 1 bbl from my 216 is in great shape. Can use this on the 55 235 I'm putting in? Need a thicker carb spacer? TIA
So many questions and winters a comin' wink
1951 1/2 ton "Buck"
Recently lobotomized for your safety.
#52305 11/13/2005 2:01 PM
The mounting bolt spacing is different. Perhaps if you used the 216 intake manifold on the 235 it might work, but I do not know if the 216 manifold will bolt up to the 235 engine.
#52306 11/13/2005 2:36 PM
Like Brian said, the mounting bolt spacing is different. I had a junk 235 carb that had a good throttle body on it. I just swapped the throttle body to the good 216 Rochester that I also had from replacing the 216 engine. It worked fine. cool
#52307 11/13/2005 10:06 PM
I had a good 216 carb so I just swapped the 216 manifold and carb all together. You just have to remove the rings on the intake port. Had worked fine so far (couple hundred miles). Good Luck.
#52308 11/14/2005 12:33 AM
I thought the difference in bolt spacing was 1/16" of and inch...this is rat tail file territory!
Stuart
#52309 11/14/2005 2:11 AM
TT
Offline
I'll look at the bolt holes and see how close it is...so if it is "rat tail file" territory...am I good to go? Should I use the thicker spacer? Otherwise assume jets etc. are fine right? Hate to waste it.
1951 1/2 ton "Buck"
#52310 11/14/2005 2:40 AM
TT,
I might have steered you wrong..not the first time I did this though. The book indicates bolt spacing on a 216 CI is 2 5/8" and the spacing on a 235 CI is 2 15/16". This is out of rat tail file territory I think. I don't know if any jetting would be smaller on the 216 engine as opposed to the larger 235. I thought I had seen a post from carbking earlier indicating the cubic inch difference had to be greater than that before the carburetor was re-jetted. If the carburetor fits, or can be made to fit easily, it won't cost you anything to try it.
Stuart
