7 members (BarryP, UtahYork, Frank50, Jon G, Gazz, Ole49GMC, 1 invisible), 101 guests, and 3 robots.
Topics128,134
Posts1,056,740
Members48,454
Junior Member
Junior Member
Hi; As near as I can tell from the casting numbers on my 235 I have a 1956 head and a 1958-1962 block. This is in my 1954 3100. I have a 1954 manual. Will the specifications from the 1954 manual for valve lash adjustment work? I assume timing, points etc. will be the same. Head = 3836848. Block = 3738307. I also assume all 235 heads and blocks are interchangeable - that right?
Thanks.
Rich
Riding in the Passing Lane
The valve lash is the same unless it has hydraulic lifters which came on cars with powerglide. The 848 head is the most desireable one it has more compression than the others.
1972 Chevy c10 Cheyenne Super
