3 members (klhansen, UtahYork, 1 invisible),
114
Mod | | | Forums66 Topics128,090 Posts1,056,374 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52302 11/13/2005 5:23 AM | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | Hi; As near as I can tell from the casting numbers on my 235 I have a 1956 head and a 1958-1962 block. This is in my 1954 3100. I have a 1954 manual. Will the specifications from the 1954 manual for valve lash adjustment work? I assume timing, points etc. will be the same. Head = 3836848. Block = 3738307. I also assume all 235 heads and blocks are interchangeable - that right? Thanks. Rich | | |
#52303 11/13/2005 5:59 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The valve lash is the same unless it has hydraulic lifters which came on cars with powerglide. The 848 head is the most desireable one it has more compression than the others. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
