3 members (Rich'sToys, Ponchogl, Peggy M), 332 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#5227 03/18/2003 5:43 AM
Junior Member
Junior Member
Is there a way to bleed brakes without using the bleeding screw? My rear passenger side is rusted and stripped. I have tried heating it to no avail, maybe I didn't heat it enough? the screw turned cherry red and started to bubble, still wouldn't turn. Any ideas would be appreciated.
David
54 1ton
#5228 03/18/2003 5:50 AM
Take that wheel cylinder out and you should be able to work out the bleeder. It is made of a much softer material. Drilling or easy out should work fine.
54 3100 with 235
62 flatbed dump C60 with 261
#5229 03/18/2003 6:19 AM
If you can get the metal line loose you can bleed it that way. I dont know what year of vehicle you have but alot of wheel cylinders will interchange through out alot of years. example I used 75 chevy 1/2 ton rear wheel cylinders on my 53 olds 88 and I got them at the discount parts store instead of paying alot more from the old car specialty shops
#5230 03/18/2003 1:10 PM
If the bleeder screw is rusted , the chances are that the rest of the wheel cylinder is not in the best of shape. I would replace the wheel cylinder..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#5231 03/21/2003 10:43 PM
V
V Offline
I really shouldn't mention this but the Bendix factory guy taught me in a brake tech class many many years ago.....
Remove drum and peel back the rubber dust cap & insert a .002" feeler gauge in between the piston and cylinder untill it begins to dribble , have a helper pump the brake pedal and stop when bubbles stop coming out - one must be very carefull with a rag to prevent any brake fluid from reaching the lining or the game's over .
Note : this can kill old brake cups that only have a tenuous seal in the first place , any signs of leakage when the dust cap is peeled back means no go , you must rebuild / replace the offending cylinder .
This method also works quite well on vertical slave cylinders like those used in older C- series
trucks from that other brand - you know the bad one ('F') .
When bleeding brakes , _always_ use _ONLY_ a 6 point box end wrench to help prevent stripping and when faced with older machinery , before anything , smack the bleeder nipple hard with a 32 Oz. ball pien hammer _before_ you try to open it , 99 % of the time this will shock it and release it .
Good luck and have fun ! .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
