0 members (), 91 guests, and 1 robot.
Topics128,055
Posts1,055,782
#521962 03/28/2009 5:46 PM
I would like to put hubcaps on the front of my '53 2 ton does anyone know witch ones will work over the lugs?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #521968 03/28/2009 6:01 PM
No hubcaps were ever available for a 2 ton. The only ones I have ever seen were on a Chevrolet show vehicle which transported the autorama displays around.
Bruce
My Trucks
Stuff I Collect
If it has disc wheels you could probably make something that would attach. I remember Reo's, Whites and Diamond T's with chrome hubcaps on spoke wheels when I was a kid so It can be done on those too.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I think that your maybe looking for "wheel simulators". They are polished stainless steel covers that go over steel wheels to give the look of polished or plated wheels. Look at www.rvwheel.com. Take a look.
NO just hub caps thanks.53moneypit,your just up the road from me.
1953 Chevy Two-Ton
PapaJ #522022 03/28/2009 9:15 PM
Actually guys there were some hubcaps available for the 1 1/2 ton, & up trucks. I have a couple of them. One front, & one rear. Only saw GMC versions though. The fronts secured to the lug nuts, & the rear were secured by a recessed screw to the center of the axle flange.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #522144 03/29/2009 6:18 AM
Nothing specific for GMC, but white had hub caps for the Yellowstone park tour busses, that clipped to a clip plate that was held on by the 6 front wheel nuts and covered just the wheel nuts, also the rear had the same setup to hold them on but looked like a top hat that covered the axle end.
ABento #522532 03/30/2009 4:39 AM
If I find something that works I'll let you guys know.
1953 Chevy Two-Ton
PapaJ #522820 03/31/2009 12:10 AM
Here's a photo of what one of the caps I have looks like, photo courtesy oldcarkook www.oldgmctrucks.com http://rides.webshots.com/photo/2134137490030786630zJPKAN
Spanky Hardy
1950 GMC 250 1-Ton
spanky #522863 03/31/2009 2:14 AM
im looking for a set of them for my 40 one ton.
I've also been looking to do the same on my '54 1-1/2 ton. What i'm going to do is use '54 1/2 ton caps and get some custom-made adapters to allow them mount on the wheel clamps(?) that mount between the lug nuts and the wheels. You'll probably beat me to this though since I have more important priorities with my truck (like my engine cooling system). Hope this helps.
