| | | Forums66 Topics128,114 Posts1,056,285 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I'll admit I don't know an awful lot about carburetors, so I need your help. My 1949 1/2-ton Chevy has a 1959 235 engine. The engine includes what appears to be the original single-barrel Rochester Model BC carburetor. The carburetor has an automatic choke which is controlled by a stovepipe from the exhaust manifold. Meanwhile, the 1949 cab has a manually controlled choke cable. I assume that by 1959 the automatic choke replaced the manual choke cable controlled by the driver in the cab. Is this correct?? I'd like to keep the manual choke. Is there a problem if I remove the stovepipe from the exhaust manifold and connect the manual choke cable from the cab?
My second question is also related to the choke. The linkage rod which connects to choke butterfly shaft to the throttle butterfly shaft is missing. What function did the linkage serve? Do I need this linkage if I plan to use the manual choke cable?
Thanks! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The linkage opens the throttle some when the choke is pulled out. You would probably be better off getting the linkage from another Rochester B. There may be other differences too. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Trucks used a manual choke in 59, you likely have a carburetor and intake manifold from a car. The choke and related linkage are the main differences between the two models. Fred
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will have to change carbs or at least the upper part to go to the manual choke. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | If you're going to replace...I suggest the Carter 3211S auto choke 1bbl. Much better carb with electric choke. This was a excellent replacement for the sub-standard Rochester's. | | |
