7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy), 161 guests, and 3 robots.
Topics128,108
Posts1,056,237
Members48,437
#522566 03/30/2009 6:22 AM
I'll admit I don't know an awful lot about carburetors, so I need your help. My 1949 1/2-ton Chevy has a 1959 235 engine. The engine includes what appears to be the original single-barrel Rochester Model BC carburetor. The carburetor has an automatic choke which is controlled by a stovepipe from the exhaust manifold. Meanwhile, the 1949 cab has a manually controlled choke cable. I assume that by 1959 the automatic choke replaced the manual choke cable controlled by the driver in the cab. Is this correct?? I'd like to keep the manual choke. Is there a problem if I remove the stovepipe from the exhaust manifold and connect the manual choke cable from the cab?
My second question is also related to the choke. The linkage rod which connects to choke butterfly shaft to the throttle butterfly shaft is missing. What function did the linkage serve? Do I need this linkage if I plan to use the manual choke cable?
Thanks!
The linkage opens the throttle some when the choke is pulled out. You would probably be better off getting the linkage from another Rochester B. There may be other differences too.
1951 1 Ton Completed
Trucks used a manual choke in 59, you likely have a carburetor and intake manifold from a car. The choke and related linkage are the main differences between the two models.
Fred
Riding in the Passing Lane
You will have to change carbs or at least the upper part to go to the manual choke.
1972 Chevy c10 Cheyenne Super
If you're going to replace...I suggest the Carter 3211S auto choke 1bbl. Much better carb with electric choke. This was a excellent replacement for the sub-standard Rochester's.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
