Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (UtahYork, Woodcmiami, frogfarmer, Otto Skorzeny, cmayna, 2 invisible), 123 guests, and 4 robots.
Topics128,281
Posts1,058,482
Members48,490
Hi all. just a question. I had installed a new fuel sending unit in my 65 and wired it to a new fuel gauge but it seemed to not work correct. I found the wire that was broken from the old fuel gauge to the sending unit. now with the ignition off my fuel gauge reads full and when i turn the ignition on it reads only three quarters. The fuel tank is full. Any answers would be greatly appreciated. Thanks
Ex Hall Monitor
Ex Hall Monitor
There have been a ton of threads about how to trouble shoot the sending unit/fuel gauge. Take the "search" link just above your post & put Gas Gauge in the search box. You'll find what you seek. grin
there's $20 bucks for whoever comes over and fixes mine. grin
I
I Offline
Mine is empty at 1/4 full. Makes for a crappy night without heat if under estimated. BRRRRR!!! Go away winter !
