3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#522375 03/29/2009 9:34 PM
Apprentice
Apprentice
Hi Guys.
I read the tech tip on replacing king pins however I Have run into a problem.
I have removed the lock rings from the top and bottom as well as the greese fittings and lock pin as per the instruction.
The problem is I cannot remove the dust caps from the assembly. is there a trick to remove them or can i just use a press to push out the whole King pin assembly with the dust caps
thanks
chaimv #522404 03/29/2009 10:56 PM
Riding in the Passing Lane
You need to pull the top plug out if you are pressing it out through the bottom. A hammer & chisel ought to get it out. They are pretty soft.
1972 Chevy c10 Cheyenne Super
Use a punch on the top one. Put a hole in it and lever it out. Then the bottom one can be pushed out with the kingpin.
What kind of truck do you have woth lock rings?
1951 1 Ton Completed
truckernix #522505 03/30/2009 2:54 AM
Apprentice
Apprentice
its not a truck it a 51 chev styleline
thanks guys will try
chaimv #522519 03/30/2009 4:02 AM
My dust caps were set in place via "peening" of the edges in 4 places. Drilled a hole in the cap and pressed the pin out as Wrench and Trucker state. Then flipped them over and pushed the cap out fom the back side.
When I put the new ones in I put a tad of JB Weld on them instead.
Brett
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Cavebull #522525 03/30/2009 4:28 AM
chaimv,
I noticed your rig was a car. Aren't king pins indigenous to straight axles only. What kind of front suspension does a Styleline have.
Stuart
atomarc #522606 03/30/2009 12:50 PM
Stuart,
I had the same question; however, here are king pins for Chevy cars through 1954. Looks like the "swing-arm" open-type knee-action 49-54 suspension still had king pins ( gone in 1955 ) ?
Tim
atomarc #522608 03/30/2009 12:52 PM
I am going to guess that there is a vertical kingpin known as the "master" kingpin and then there is a kingpin in the lower and upper hinge. This was the early form of independent suspension without ball joints.
truckernix #522625 03/30/2009 1:40 PM
Apprentice
Apprentice
Just one master Kingpin that goes from the bottom of the steering knuckle to the top.
thanks guys. i will le tyou know how it goes
chaimv #522673 03/30/2009 3:46 PM
How interesting....never too old to learn. smile
Stuart
atomarc #523288 04/01/2009 3:40 AM
Apprentice
Apprentice
thanks guys
I got one out. Now i am trying to install the new pin and bushings. the bushings are going in very tight. is this normal.
also the kit came with 2 bearings and 2 washers. i assume one of each for each kingpin. does the bearing go on the bottom or on the top?
thanks
chaimv #523356 04/01/2009 11:02 AM
Because this is not a truck, you need to find out how the bushing is supposed to go in. With the trucks, the lighter models have "floating" bushings and the heavier ones have pressed in bushings that are reamed to size.
