| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Hi Guys.
I read the tech tip on replacing king pins however I Have run into a problem.
I have removed the lock rings from the top and bottom as well as the greese fittings and lock pin as per the instruction.
The problem is I cannot remove the dust caps from the assembly. is there a trick to remove them or can i just use a press to push out the whole King pin assembly with the dust caps
thanks
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to pull the top plug out if you are pressing it out through the bottom. A hammer & chisel ought to get it out. They are pretty soft. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Use a punch on the top one. Put a hole in it and lever it out. Then the bottom one can be pushed out with the kingpin.
What kind of truck do you have woth lock rings? | | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | its not a truck it a 51 chev styleline
thanks guys will try | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | My dust caps were set in place via "peening" of the edges in 4 places. Drilled a hole in the cap and pressed the pin out as Wrench and Trucker state. Then flipped them over and pushed the cap out fom the back side. When I put the new ones in I put a tad of JB Weld on them instead. Brett | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | chaimv,
I noticed your rig was a car. Aren't king pins indigenous to straight axles only. What kind of front suspension does a Styleline have.
Stuart | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am going to guess that there is a vertical kingpin known as the "master" kingpin and then there is a kingpin in the lower and upper hinge. This was the early form of independent suspension without ball joints. | | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Just one master Kingpin that goes from the bottom of the steering knuckle to the top.
thanks guys. i will le tyou know how it goes | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | How interesting....never too old to learn. Stuart | | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | thanks guys
I got one out. Now i am trying to install the new pin and bushings. the bushings are going in very tight. is this normal.
also the kit came with 2 bearings and 2 washers. i assume one of each for each kingpin. does the bearing go on the bottom or on the top?
thanks
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Because this is not a truck, you need to find out how the bushing is supposed to go in. With the trucks, the lighter models have "floating" bushings and the heavier ones have pressed in bushings that are reamed to size. | | |
