3 members (Gib70, Nick in Manitou, Wally / Montana), 104 guests, and 4 robots.
Topics128,088
Posts1,055,998
Members48,430
#52228 11/11/2005 5:46 PM
Finally got most of the pieces to the 700r4 in my 55 1st series truck. Truck originally had a hydra-matic. I want to use the existing column shift. Has anyone had experience in doing a conversion like this? Looking for suggestions on shifter linkage and TV cable hookup (have Offenhauser intake with 2 Carter/Webber carbs. No offense, but please don't tell me to go Langdon or Inliners. Looking for a real live experience. Thanks
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#52229 11/11/2005 7:11 PM
If you have trouble mounting the TV cable to the carb(s), a remote bellcrank may be the solution. Worked for me, albeit my set up is different.
http://www.chuckthetruck.com/Page26.html
#52230 11/12/2005 1:20 AM
Chuckthetruck,
Great information. I wasn't following too well until you clarified that the standard transmission and clutch parts were still in the truck. As I get this project underway i'll take pictures to share. As always, the help here is the best anywhere.
Thanks again for the help!
cgresham1212
#52231 11/14/2005 5:48 AM
3B Offline
I am assuming that you have the bellhousing adapter plate, flywheel, and it's adapter. T.V. cable adjustment is CRITICAL!!! on this transmission if it's not done correctly you will burn up your clutches. It's not like the old days open the throttle and adjust the cable so that its all the way out when the throttle is fully open. I think you should contact someone like Pheonix transmission about T.V. cable linkage.
#52232 11/17/2005 5:32 AM
I am about to put that 700r4 in my 72 and found this as a good resource:
http://bowtieoverdrives.com/catalog/catalog.php?Action=GETSUBCAT&CATID=OA1A3
Since I am not far from you I would like to find out more about how it worked out for you if you get the chance - thanks.
#52233 11/18/2005 1:11 AM
arnswine,
Will be glad to keep you updated on the progress. Hope to get a TV cable bracket and carburetor stud in the morning. I have a Buffalo adapter and flywheel. Biggest hurdle will be making the rear motor mounts and getting the driveshaft cut to length. I think! Bowtie is a good information source. I have ordered their electric lockup kit.
cgresham1212
#52234 11/18/2005 1:52 AM
I am going to get that as well, and probably the pressure gauge to check/set the TV cable.
